Using Ableton MIDI as an expression pedal for M5
mousepunk
Hello. I use DAW to control my M5 (switching presets). The manual says I can use DAW to control preset parameters with MIDI CC like I use the expression pedal. But how do I assign particular parameter of the preset to be changed with the MIDI CC? With expression pedal you choose the parameter with tweaking it when you plug the pedal in expression input, but I could not find the instruction to choose preset parameter without expression pedal. Anybody tried to do that? It expands M5's possibilities very much, because you can build any additional tone on the basis of 24 existing presets, you can make delay oscillating when it's needed, can change the Whammy's note in real time etc. Any help is appreciated.
  • 1 year later...
