Sign in to follow this
Rocco_Crocco
Dual cabs... Only one is working
Running 2.20.
I am creating a preset with dual cabs. Only the last cab I picked from the cab list  is working. I can turn down the volume on the last cab selected and I get silence. If I turn it back up, then go to the other cab and turn down the volume, there is no change in tone or volume.
Bug?
As a data point:
I tried every which way to recreate this; couldn't do so.
(Two single cabs on parallel paths, then a dual-cab block - was getting processed signal in all cases)
I'm also on v2.20, using Helix Rack/Control.
I am refering to a dual cab block, not 2 independant cab blocks.
Indeed.
I tested that out as well, in case that's what you meant.
I couldn't duplicate it.
I wonder what the variance is from one Helix to another which causes some of these bugs to show up in some but not all units?
Can you post a patch that misbehaves this way so that one of us can load it and see what we get?
Indeed.
Hmmm. I just got home from work and dialed in the saved patch that gave me the issue so I could post it. Now its working fine.
Here is the patch anyway. See what happens if you try...
https://app.box.com/s/lremiaoxcktd8fqktxkdhv88bfm0v0c6
Maybe turning the unit off and on fixed the glitch.
Anyone figure this out? I'm having the same problem with dual cabs. A works B is 100% off.
Do post your preset here. I'll take a look.
I haven't looked at the preset - can't right now.
The dual-cab pans one cabinet hard-left and the other one hard-right. It is possible your output block is panned full right or left, effectively silencing the other cab?
Create an account
Register a new account
Sign in
Sign In Now
