Settings within HD500Edit
MikeTicehurst
Hi I have started using my HD500 taking a mono output into the front of an amp. I am no longer using the modelled amps, & just using the effects. I noticed that there appeared to be a jump in volume between patches & looking in HD500 Edit I then saw the the "mixer" on some was panned hard left & right & the faders both set at 0db.
I have therefore set the right fader to "mute" & set the left fader to 0db & the pan set to "centre"
My question is this
Have I set this correctly, or should both faders be set to 0db & panned to centre?
Or does it make any difference, apart from the increase in volume?
You could just use the L/MONO 1/4" output from the Pod to your amp. This sums the signal to mono. Leave the preset settings as they are unless you want to achieve something other than a full, but mono, signal to your amp input.
I would leave them both at 0db and panned Center. Both paths are stereo and need to be panned center if you want to hear any stereo FX. Since you want a mono feed I would let the L/MONO output jack do that job and retain the stereo separation in the preset in case you want it in another circumstance, like going direct to PA sometime.
