reggibeasley
Help??? How to undo push and turn in snapshots?
Hi guys. I use push and turn in snaphsot mode to adjust specific settings to individual blocks- such as gaining the amp up in snapshot one, then gaining it down in snapshot 2. What I can't seem to figure out is how to remove the push and turn so that it goes back to being universal across all snapshots. Thanks for the help in advance.
Hold the bypass button and then immediately push the control encoder knob for the parameter you wish to de-assign - that's the quickest way - brackets will vanish immediately.
(I've accidentally twist-turned quite a few times....)
  • Upvote 4
Cool, I didn't know about that one! What I've always sooner is go into controller assign for that parameter, and select none.
This will probably sound silly, I'm a complete noobie to the Helix, but why do you have to get the white text up in brackets per snapshot?
Think I've been just turning the nob without pushing it too, then saving per patch.
Not sure I understand what you're saying, but without the brackets, that parameter isn't controlled by snapshots (or any other controller), so it has the same value in every snapshot.
OK thanks, I understand now.
