Maybe simple question
Flotsam71
Is AUX input the same as say return one?? I am playing around with wet dry wet and the video I watched has routing from right output to AUX in for wet effects...then out through 3/4 sends. Why AUX ...why not return 3...or 4....thanks anyone!!
Aux in is LESS hot, I think, than a return, because it's designed to handle a preamped signal coming in, and the Return is designed so that it can be set for line or instrument.
An electric guitar (I found after testing) only works totally right in the guitar input.
The particular usage you describe sounds wacky and unnecessary, since you can do so much of that kind of routing inside Helix, but to each their own.
I know the routing options are crazy good. But for a true W/D/W with three physical amps...how else would this be accomplished? Path 1 to dry and path 2 in stereo to 2 wet amps?? So many options I'm trying to figure out the best way.
