tochiro Posted May 3, 2017 Share Posted May 3, 2017 Hi, I see a Preset or Pedal screen in all videos that can be used to replace the scribble strips of the "big" Helix. But is there a snapshot screen on the LT I can use in the same way? Thank you. Cheers 1 Quote Link to comment Share on other sites More sharing options...
ADBrown Posted May 3, 2017 Share Posted May 3, 2017 This view on the LT that takes the place of scribble strips you are referring to is called "Performance View", and yes, you can view snapshots the same way. You can also set it up in any way you could with scribble strips, ex: stomp/snap, snap/preset, snap/stomp, etc. Quote Link to comment Share on other sites More sharing options...
brandondoral Posted May 9, 2017 Share Posted May 9, 2017 how do i set up snapshots on LT? I'm super confused Quote Link to comment Share on other sites More sharing options...
jwor86 Posted March 8, 2018 Share Posted March 8, 2018 I'm trying to use the snapshots options too in the Helix LT. I go to global setting. Change to Preset/Snap but when i go back to my presets. The LED screen is just load with presets. I don't seem to find the 4 snapshots options for the bottom footswitches. Quote Link to comment Share on other sites More sharing options...
ADBrown Posted March 8, 2018 Share Posted March 8, 2018 I'm trying to use the snapshots options too in the Helix LT. I go to global setting. Change to Preset/Snap but when i go back to my presets. The LED screen is just load with presets. I don't seem to find the 4 snapshots options for the bottom footswitches. Press the mode footswitch to toggle between views, you should be able to then see your preset/snap setup. Quote Link to comment Share on other sites More sharing options...
