Sign in to follow this
tochiro
Helix LT - Snapshot Screen
I see a Preset or Pedal screen in all videos that can be used to replace the scribble strips of the "big" Helix.  But is there a snapshot screen on the LT I can use in the same way?  Thank you.
Cheers
This view on the LT that takes the place of scribble strips you are referring to is called "Performance View", and yes, you can view snapshots the same way. You can also set it up in any way you could with scribble strips, ex: stomp/snap, snap/preset, snap/stomp, etc.
I'm trying to use the snapshots options too in the Helix LT. I go to global setting. Change to Preset/Snap but when i go back to my presets. The LED screen is just load with presets. I don't seem to find the 4 snapshots options for the bottom footswitches.
Press the mode footswitch to toggle between views, you should be able to then see your preset/snap setup.
Create an account
Register a new account
Sign in
Sign In Now
