Clipping Noise With Blue Comp?
Alsklaftsk123
Just stumbled of those interesting posts ...
Not saying this is your cure-all but...
1. Put the Comp before the Amp module.
2. I only use the "Tube Comp" model and I really like it... but all the others are pretty lame.
Hopefully that'll help.
I have the same opinion..
also the Vetta comp despite having only a fixed ratio (which is anyway the most commonly used) is not bad
Can you share a few tube compressor settings and describe in a few words what you use it for (material, guitar, Amp, compress or compressand + change level)?
I just posted earlier today some questions I ran into using the tube compressor.
I like the sound but the model seems to behave a little 'unexpected', i.e., it adds gain at 0% Level for Thresholds starting at <70% (about 13dB at 0% Threshold)
Thanks,
Martin
Me too...
1. I rarely use it on "High Gain" but I will check to see if it's harmonic content adds anything nice. :P
2. I typically use the same settings as hurghanico with the Gain between 5-15, the Thresh @ 20-50%; rarely ever higher and mostly on clean amps.
