eyeruleall Posted May 17, 2017 Share Posted May 17, 2017 I can't figure out how they're supposed to go back together. The amp works until I screw this part down, then it doesn't work anymore. I'm obviously shorting out somewhere. Does anyone know the correct order for bolt, spacer, washer, lock washer, and nut? Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted May 18, 2017 Share Posted May 18, 2017 The spacer (the part next to the bolt) looks like it is plastic (non-conducting?) so its most likely to prevent contact with the rectangular plate and the chassis, so needs to be inserted in the rect plate hole before inserting the bolt. Quote Link to comment Share on other sites More sharing options...
eyeruleall Posted May 18, 2017 Author Share Posted May 18, 2017 I got it. The plastic piece goes in from the bottom. That's where I was messing up. Quote Link to comment Share on other sites More sharing options...
