How to create stereo path with amps on the end
drewpreiner
Hey guys, I'm wanting to route a stereo signal using the 1/4" outputs of the Helix. Problem is I want amps to be on the end of my chain for the desired effect. How do I go about this? Attached is my screenshot attempt. Any help would be great!
Thanks,
Drew
If you want an amp(s) at the end of the chain then you would need to have two amps or two cabs since they are mono.  You could put one amp on path 1A and another on 1B and then pan them right and left respectively at the merge point. Another option is to have one of them in Path 1 and the other in Path 2 and then pan the output of the paths right and left.
Separate the amp head from the cab.
Now, use whatever amp you like, early in the chain, with your mono FX like distortions and comps and such.
Now use a DUAL cab and make sure that everything after it is stereo.
