Pod Farm - plugin sounds dry - records wet
I've just installed Pod Farm 2.5. I'm using Sonar and running it through a Scarlett 2i2 interface. When I try to use the Pod Farm plug in - I can't hear the amp effect - but if I record what I'm hearing - the amp effect does record. I must have my routing messed up somewhere - but can't figure it out. Anyone know what I might be doing wrong.
Thanks in advance.
Mark
It's sometimes called Record Monitoring. It allows you to monitor the recorded sound (post Pod Farm processing) rather than the dry input signal (pre Pod Farm processing). Inevitably there will be some latency due to the time required to process the signal; you will not hear the recorded sound until a few milliseconds after you pluck the guitar string(s).
