markcline321 Posted May 24, 2017 Share Posted May 24, 2017 I've just installed Pod Farm 2.5. I'm using Sonar and running it through a Scarlett 2i2 interface. When I try to use the Pod Farm plug in - I can't hear the amp effect - but if I record what I'm hearing - the amp effect does record. I must have my routing messed up somewhere - but can't figure it out. Anyone know what I might be doing wrong. Thanks in advance. Mark Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 24, 2017 Share Posted May 24, 2017 Is you monitoring solution connected directly to the Scarlett? Have you tried turning on "Track Monitoring" in Sonar (not sure of the exact terminology in Sonar)? Quote Link to comment Share on other sites More sharing options...
markcline321 Posted May 24, 2017 Author Share Posted May 24, 2017 My guitar is going directly into the Scarlett. I will have to see what is up with Track Monitoring - that's a new one to me. Mark Quote Link to comment Share on other sites More sharing options...
markcline321 Posted May 25, 2017 Author Share Posted May 25, 2017 I can't find anything like track monitoring. Still can't get it to work. Quote Link to comment Share on other sites More sharing options...
markcline321 Posted May 25, 2017 Author Share Posted May 25, 2017 Got it fixed. Thanks. Mark Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 25, 2017 Share Posted May 25, 2017 It's sometimes called Record Monitoring. It allows you to monitor the recorded sound (post Pod Farm processing) rather than the dry input signal (pre Pod Farm processing). Inevitably there will be some latency due to the time required to process the signal; you will not hear the recorded sound until a few milliseconds after you pluck the guitar string(s). Quote Link to comment Share on other sites More sharing options...
