calojer Posted May 25, 2017 Share Posted May 25, 2017 Hi everybody, I noticed that I can't get a Crunch sound with Tweed B-man Brt Pre amplifier, without using other FX. Drive Vol to 100% and Channel Vol to 100% doesn't get a Crunch sound just as it would make a true Bassman amplifier. Is it normal? Thanks! Quote Link to comment Share on other sites More sharing options...
bjnette Posted May 25, 2017 Share Posted May 25, 2017 It seems to be normal for the pre models but the full amp model will breakup when volume and gain on full. Quote Link to comment Share on other sites More sharing options...
Ed_Saxman Posted May 25, 2017 Share Posted May 25, 2017 Some amps have all the dirt in the "Pre" while many others have it on the poweramp (modeled in the full amps) Unless you have a DT amp, It does not make much sense to use the Pre versions. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted May 25, 2017 Share Posted May 25, 2017 From my distortion measurements here, the table shows that the Tweed B-man is a very clean amp, so you may need more signal than normal. The graphs show that the PowerAmp has more gain than the Preamp. So if you want crunch, you should use the full model. Quote Link to comment Share on other sites More sharing options...
calojer Posted May 26, 2017 Author Share Posted May 26, 2017 Thanks to you all! Quote Link to comment Share on other sites More sharing options...
