How to connect HD500x to ipad to record on Garageband App?
retuned
I want to use my HD500x to record in the Garageband App on my ipad.
I want to use the tones in my HD500x to record, I don't want to use the Mobile POD App.
What should I use to connect my HD500x to the ipad.
Thanks
Rob
Thanks Atrain_dip, ive done a bit of research & i think the irig pro fits my needs.
Question:
Your Apogee Jam only has 1 jack input. Do you have to use a Y cable from your pod Left & Right outputs to the Apogee to get stereo effects (ie ping pong delay).
  • 4 weeks later...
Thanks jvrock84, just a question regarding stereo effects (eg. ping pong delay).
Did you have to connect your Pod HD500x to the iRig using a Y cable in order to achieve stereo effects on your DAW in your ipad.
Thanks jvrock84, just a question regarding stereo effects (eg. ping pong delay). Did you have to connect your Pod HD500x to the iRig using a Y cable in order to achieve stereo effects on your DAW in your ipad.
No, never tried that, but I assume it should work. Just be careful, I don't how much the iRig can resist, try it at low levels.
