jkuche Posted May 26, 2017 Share Posted May 26, 2017 Been with Line 6 since original POD. Just opened Helix LT box. Downloaded some great acoustic patches - tone is amazing . But some are silent and I can't figure out why. Tuner is fine, but no sound. Is there a mute block hidden? I'm having difficulty assigning P1 to volume. Was easy on Firehawk, POD , etc . What am I missing on these issues? Lastly- is Helix editor not fully functioned ? i.e.- must I still go to the Helix for various tweaking. Apologize for any redundant thread. j Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted May 26, 2017 Share Posted May 26, 2017 Do any of the patches have IR blocks? What are the input icons set to? Be sure to check output blocks as well. What input are you plugged into? By P1 do you mean Expression Pedal 1 (EXP1)? A volume pedal block is automatically assigned to EXP1 when you place it in the chain. Are you sure there's one in your chain? Quote Link to comment Share on other sites More sharing options...
arislaf Posted May 26, 2017 Share Posted May 26, 2017 Check input, maybe it is set to variax. Check if there is a return/sent block. Delete it. Check output parameter. Set it on multi. Quote Link to comment Share on other sites More sharing options...
Rocco_Crocco Posted May 26, 2017 Share Posted May 26, 2017 ^^this Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 26, 2017 Share Posted May 26, 2017 Double check all of your inputs and outputs. I would start by turning all of the effects off. Then see if you hear anything. If not, adjust your inputs and or outputs. Don't forget to check what the split signal's (if there are any) inputs and outputs are set at. Once you hear something then, turn on each effect until the sound disappears. Check out the setting of whatever effect cuts the sound out. Quote Link to comment Share on other sites More sharing options...
RRMark Posted May 27, 2017 Share Posted May 27, 2017 Some presets I've downloaded needed the volume pedal moved from toe down to heel and back up, to hear anything. Presume they are saved with volume block set to zero, and depends on the global setting being per preset. Quote Link to comment Share on other sites More sharing options...
