Sign in to follow this
brandonvu1997
M9's Footswitch Activated By Itself
My M9's record footswitch seems to have a habit of turning itself on. Whether I'm activating another pedal or turning on a separate preset, it would just start recording a new loop or turn on the reverb I have set to it. It's quite annoying and I can't use it anymore. I've tried looking at the footswitches inside, and one of the springs was a little weird. I switch the little screws that pushes and activates the switch for the record and stop switches, and the problem was moved to the stop switch. I decided to temporarily switch the bad screw/spring to the tap tempo so I can still use it as a looper, but the problem came back to the record after 10 minutes of playing! I also found that the footswitch itself doesn't click like the others do when you press it. Anyone have any ideas?
