Sign in to follow this
timthompson
POD HD Edit
I have installed Line6 monkey, and updates were successful. and installed pod hd edit, and when I pull up hd edit , it gives me this message:
Could not detect a POD HD connected to your computer.
POD HD Edit will run in offline mode.
could anyone tell me what I need to do. TX Tim
Make sure you have the HD Edit for your version of HD too. I only say this as recently a user was trying to use HD Edit instead of the HD500 Edit (for a HD 500).
Yep.   Some real dumbsh&t was trying to do that.
Tim.  Make sure you're using the correct version on HD Edit.
It happens my man. Like the time I couldn't figure out why I had no sound and the amp was still on standby. :)
Thanks guys; I will try your suggestions. I'll let you know if it works. And yes I tried different USB ports.
