Ezzra Posted June 6, 2017 Share Posted June 6, 2017 I recently bought my Helix and am loving it! But I have one minor problem: When I switch on the Helix, the Expression Pedal shows EXP 1 and EXP 2 and I can toggle between the two settings using the Toe switch. However, after a while the expression Pedal only shows EXP 1 and the toe switch is not active. The only way I have found to reset is to switch off the Helix and switch it back on again. Is there something that I may have done to cause it to only display EXP 1? How can I reset without switching the Helix off? There doesn't appear to be anything in the manual about this. Thanks Errol. Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 6, 2017 Share Posted June 6, 2017 You need to update the firmware. This was a bug in version 2.10, and it was taken care of in the subsequent update, 2.11. But you should just update to the latest version - 2.21. The instructions are listed in the sticky on the top of the forum page: http://line6.com/support/topic/18284-latest-helix-firmware-221%E2%80%94april-27-2017/ Quote Link to comment Share on other sites More sharing options...
Ezzra Posted June 6, 2017 Author Share Posted June 6, 2017 Thanks for confirming it was a bug. I'll update to the latest firmware. Quote Link to comment Share on other sites More sharing options...
