alvinsg Posted June 21, 2017 Share Posted June 21, 2017 Hey guys, I finally got time to mess around with my Line 6 POD HD PRO so I downloaded POD HD Pro Edit to start making tones. Problem is, no matter how many times I install the driver and reset the my Mac, the driver never actually installs and Monkey wants says my device is not connected. I'm connecting via USB (the Rocksmith cable to be exact, I've been told it works for this) if that helps. I'm connecting it via the dry output but I'm not really sure what the difference is between all the in/out stuff back there. I'm sort of new to this so yeah. Any help would be appreciated! Quote Link to comment Share on other sites More sharing options...
bjnette Posted June 21, 2017 Share Posted June 21, 2017 Though I am not on a Mac this might not be too much help. Make sure your USB is not via a hub. Go the main USB. On PC you need monkey and this might be all you need. Let Monkey do the install for you. On the older PCs you can uninstall the drivers and HD EDIT then at startup the OS wants to find driver for the HD or device. In case via monkey is a prob.Good luck Quote Link to comment Share on other sites More sharing options...
