G30 transmitter alternative power source
Lanzoyd
I'd like to use a USB powerbank instead of 2x AA batteries, as doing so would give me much more battery capacity and in general would be more convenient for my purpouse.
Question is:
- can the transmitter operate under 5V or will it break anything?
Thank you in advance!
Question is:
Depending on if the 2xAA batteries are in series (7vdc) or parallel (3.5vdc), you could get an appropriate DC to DC converter board/module to convert from 5vdc on the power brick to whatever you need for the transmitter. A quick search at Digikey will get you in the right direction.
AA batteries are 1.5v in series, for a total of 3vdc, that's why I was asking before connecting a 5vdc power source.
I'd like to avoid adding a tension regulator...
Oh yeah...duh. I was shopping for a specialty rechargeable battery last week that was 3.5v. I guess that was stuck in my tiny brain.
Either way, DC to DC converter can still go from 5v to 3v if that what the transmitter is using.
