cyberi4n Posted June 21, 2017 Share Posted June 21, 2017 Hi all. Noticed tonight that my HD Pro X patches were doing something weird. Whenever I'd change patch, the display would flick between the amp/fx blocks view and the Amp controls view, and the amp volume would flick between 1/2 % of wherever I set and saved it. For example, if I assign a volume of 65%, it would flick between 65 and 66%. I also noticed that whereas before the tap tempo light on the floorboard and the tap light on the front of the unit would be perfectly in sync, now they were drifting away from each other. The tempo light on the floorboard would be consistent with the delay tempo, but the one on the unit itself would be out of time. Overheating issue? The unit WAS getting hot! Or does this point to a deeper (more terminal) issue? Quote Link to comment Share on other sites More sharing options...
bjnette Posted June 21, 2017 Share Posted June 21, 2017 Hopefully all you got is a failure to save changes. Check that the save function is working perfectly. Some compressed air clears it most of the time. If it occurs again and again, isolate any change you make so you can replicate it. Cheers Quote Link to comment Share on other sites More sharing options...
cyberi4n Posted June 22, 2017 Author Share Posted June 22, 2017 Thanks. Powered up the unit this morning, albeit with no guitar or foot switch connected. Seemed to be stable. I'll just have to leave it a few days and observe what's happening. Quote Link to comment Share on other sites More sharing options...
bjnette Posted June 22, 2017 Share Posted June 22, 2017 Oh yeah, another way the HD will trip you is if one of your cables gets between any knobs on the amp controls. Less likely on a HD Pro no doubt. Hope it stays stable for you! Quote Link to comment Share on other sites More sharing options...
