Overturept Posted June 21, 2017 Share Posted June 21, 2017 Hello, i've purchased an ipad mini to use with amplifi (It says on line6 requirements that it's supported), turns out that the store version requires IOS10 and ipad mini doesn't have IOS 10, it has been discontiued to this device. So, is there any option to install a IOS9 compatible app? Can you provide since i cant get it in store? Regards. Quote Link to comment Share on other sites More sharing options...
cbrillow Posted July 3, 2017 Share Posted July 3, 2017 Hi, doesn't look like you've received any responses yet. My situation is a little different, but still similar to yours. Here's my (limited) experience as a new Amplifi user. Amplifi 30 and the Ampli FX 100, both updated with the latest firmware iPad 3rd generation w/last version of iOS 9.3.5 Android phone with latest version of Android 7.1.1 Amplifi remote app, version 2.6 on both devices Although I'm still getting my feet wet, things seems to be working as-intended. Given that my iPad is older than yours, I'd expect that your results should be similar. Quote Link to comment Share on other sites More sharing options...
vicutix Posted August 4, 2017 Share Posted August 4, 2017 Hi, I just bought a guitar Variax JTV 59 and an Amplifi 75. My problem is that I have an iPad that only supports IOS 9 and can not download the app to control the devices. How can I do without buying a new iPad? thank you so much claudio Quote Link to comment Share on other sites More sharing options...
cbrillow Posted August 6, 2017 Share Posted August 6, 2017 Hi, I just bought a guitar Variax JTV 59 and an Amplifi 75. My problem is that I have an iPad that only supports IOS 9 and can not download the app to control the devices. How can I do without buying a new iPad? thank you so much claudio Hmmmmm... I have a JTV59 and a 3rd generation iPad with the last version of iOS9 and the latest AMPLIFI firmware. Everything works just fine. I'm also a fairly recent purchaser of the AMPLIFI -- acquiring it in the past several months. It appears that you're suggesting that the Apple store no longer offers the AMPLIFI app - is that what's happened in your case? Quote Link to comment Share on other sites More sharing options...
louinpa Posted January 26, 2018 Share Posted January 26, 2018 Hmmmmm... I have a JTV59 and a 3rd generation iPad with the last version of iOS9 and the latest AMPLIFI firmware. Everything works just fine. I'm also a fairly recent purchaser of the AMPLIFI -- acquiring it in the past several months. It appears that you're suggesting that the Apple store no longer offers the AMPLIFI app - is that what's happened in your case? I purchased an Amplifi 75 ,own a iPad mini with iOS9.3.5. The Amplifi app in the Apple store will not install without iOS10 or better on an apple controlled device. My iPad mini will not upgrade to iOS10. The end result is; I cannot update the Amplifi app or the Amplifi 75 unless I buy a new iPad or Apple device. Already got costly without even trying. The worst part is: the Line6 requirement clearly states iOS9 or better. So Line6, is there a way to get an older copy of Amplifi Remote App which will run on iOS9 (as was stated in the requirements) ? 1 Quote Link to comment Share on other sites More sharing options...
micas1973 Posted January 27, 2018 Share Posted January 27, 2018 I purchased an Amplifi 75 ,own a iPad mini with iOS9.3.5. The Amplifi app in the Apple store will not install without iOS10 or better on an apple controlled device. My iPad mini will not upgrade to iOS10. The end result is; I cannot update the Amplifi app or the Amplifi 75 unless I buy a new iPad or Apple device. Already got costly without even trying. The worst part is: the Line6 requirement clearly states iOS9 or better. So Line6, is there a way to get an older copy of Amplifi Remote App which will run on iOS9 (as was stated in the requirements) ? I am in the same situiation. I've an iPad 2 and I'm not able to update my iOS further than 9.3.5. I've already tried to search for AMPLIFi Remote 2.50 because is compatible with iOS 9, but I had no lucky. Any one, or even you Line 6, have a solution? I want so bad to play my guitar and use my AMPLIFi 75... Quote Link to comment Share on other sites More sharing options...
Datto Posted February 18, 2018 Share Posted February 18, 2018 I have the same problem -- iPad 3 and Amplifi TT and the Apple App Store won't let the Amplifi Remote app install unless I have IOS 10 and that won't install on an iPad 3. Hey Line 6 -- Please make your older version available to us iPad users so we don't have to buy a whole new iPad just to be able to run your Amplifi Remote app. Thanks. Quote Link to comment Share on other sites More sharing options...
Overturept Posted March 13, 2018 Author Share Posted March 13, 2018 Well, after you install it for the first time with your account (i used another ipad with my account) The app started showing option to install older versions, but you still only gonna have old versions... Quote Link to comment Share on other sites More sharing options...
glaucosader Posted May 25, 2018 Share Posted May 25, 2018 On 7/3/2017 at 8:41 AM, cbrillow said: Hi, doesn't look like you've received any responses yet. My situation is a little different, but still similar to yours. Here's my (limited) experience as a new Amplifi user. Amplifi 30 and the Ampli FX 100, both updated with the latest firmware iPad 3rd generation w/last version of iOS 9.3.5 Android phone with latest version of Android 7.1.1 Amplifi remote app, version 2.6 on both devices Although I'm still getting my feet wet, things seems to be working as-intended. Given that my iPad is older than yours, I'd expect that your results should be similar. download the current version of Amplifi in the apple store, when the message appears that ios is earlier than 10, quit the app, and re-enter the app and re-install the Amplifi, which will automatically display the previous version installation option. I did it on my ipad 3 ios 9.3.5 and it is working very well Quote Link to comment Share on other sites More sharing options...
