limyu_miu Posted September 22, 2013 Share Posted September 22, 2013 Hi guys, I posted a topic a few days ago that I could hear my guitar sound from the background even though any musical software isn't running. I got a reply that it is supposed to be like that, but then it's uncomfortable for me for someone who's been using other audio interfaces like UX1. The problem is that when I play a song and try to record (while playing the song I want to cover at the same time) at Cubase, if I can hear my guitar sound without enabling the monitoring button, then I get the product with too low volume after rendering (I can't even hear anything). What I mean is that if I don't monitor my guitar sound while being recorded, I won't know what the volume of my recording is. so.. is there a way I can stop hearing my guitar sound at the back any time?? at least when Cubase is running? Please help me with it again Thanks! Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 23, 2013 Share Posted September 23, 2013 How are your speakers/monitors connected? Have you experimented with using the +18db boost available in the Line 6 Audio-MIDI Devices control panel settings? 1 Quote Link to comment Share on other sites More sharing options...
limyu_miu Posted September 23, 2013 Author Share Posted September 23, 2013 I didn't use the 18db boost (cuz I believe it distorts the original tone, doesn't it????) but then thanks to your post, I lowered the hardware monitor volume in the LINE 6 Audio-MIDI Devices control panel setting and the original problem is now fixed however, can you reply it back to me more about +18db boost? It seems useful but then when I used it in my previous computer, I got the right volume, but then the tone seemed to change (in a way it's different from when the volume was low). Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 23, 2013 Share Posted September 23, 2013 I'm not very familiar with the details of the boost - I've never used it. However, theoretically I expect it would have a similar effect to anything else that affects signal volume. Depending on how the tone is being processed, louder volume can affect the tone - like increasing your guitar volume using the knob on you guitar will affect the tone by creating more dirt/grit from the amp gain/drive setting. It is generally used to compensate for, or match with, outboard equipment (computer, DAW, ...) whose usb inputs are somehow 'quieter', whatever that means :huh: . There's no right or wrong about it - use it if you find it helpful, otherwise don't use it. Quote Link to comment Share on other sites More sharing options...
