Dazzer40 Posted July 10, 2017 Share Posted July 10, 2017 I have helix LT and I am creating one patch for a rhythm and another for lead , so basically i want path 1 to have a rhythm setup and path 2 to have a lead for soloing , I want to be able to switch between the two paths , How can I assign a single path to a foot switch ? Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted July 10, 2017 Share Posted July 10, 2017 I have helix LT and I am creating one patch for a rhythm and another for lead , so basically i want path 1 to have a rhythm setup and path 2 to have a lead for soloing , I want to be able to switch between the two paths , How can I assign a single path to a foot switch ? I am not at my Helix at the moment, so I can't explain precise steps. On the input of each path there is a parameter for gain in dB I believe. You can assign a foot switch to simultaneously turn the gain all the way down (-70db i think) on one path and turn the gain up (0db) on the other path. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted July 10, 2017 Share Posted July 10, 2017 1. Stick a volume pedal block at the beginning of each patch. 2. Assign their "position" parameter to the same foot switch. 3. Make it so that on is 100% on one and 0% on the other, and off is the opposite. 4. Done. Alternatively, you could have one foot switch that turns on path A and one for path B, and then you could have both at once if you wanted. Quote Link to comment Share on other sites More sharing options...
