Sign in to follow this
themetallikid
Wah's and Why?
So I watched a video last night regarding the different wah models and how they are basically the same, just different frequency ranges.  Is there anything else that separates the Wahs?   I'd assume there are some baked in settings regarding the 'Q' of the wah and resonance type stuff as well.
Do you have a favorite and what do you like about that one over the others?
I feel the same way about most guitars (and trees). They are all mostly made outta wood... Isn't there anything else that separates the guitars (and trees)?
I found on the Jim Dunlop website that most of the Wah pedals have manuals.  There are specs for many of the wahs listed with heel down and toe down frequencies.
For example, the EVH Wah:
Filter Parameter Low Pass ..................... 300Hz ~ 380Hz High Pass .................. 1.9kHz ~ 2.3kHz
The Q also makes each wah unique, which is the width of the frequency that is spiked.  If you like Fassel inductors then you start with the Fassel wah model.
What I hope Line6 does in the future is allow the adjustment of the Q in the Helix.  At that point you can pretty much customize the Wah to sound like whatever you want.
Now THAT is funny!!!!   :lol:
That looks to be a great resource.  Thanks Farley....
I've had several modelers with different wahs and there is usually more than a few models that just seem unusable.  Just checking if there was a 'fan' favorite in the Helix or if they are all pretty usable and different.  That video I saw seemed to really make them all sound similar when the Frequencies were evened out.  Now I understand the frequency range is a factor in the wah sound, but so is Q, resonance and such.  I assume the Helix has those parameters baked into the Wah models.
This.
Agree that all the models sound very similar outside of their frequency ranges, and that's adjustable anyway. Q really should be adjustable too.
I currently like the throaty with FcLow 350 and FcHigh 1600. But this is also in combination with the Cali IV Lead amp, a Redwirez EnglPro Tab57 12 inches and the built in XXL V30 cab in parallel. With different cabs, and possibly a different amp, my wah of choice would likely also be different.
I love the fassel with a super wide sweep, set to auto engage as soon as I leave the toe position
Alex, yes...I will also be utilizing an auto engage function with the wah as well.  Any quick starts on how that gets setup?
Also saw in the manual that when a separate EXP is attached, the onboard one defaults to EXP 1 and the external defaults to 2......but then when a volume/wah are added, they default to one of the pedals specifically...can this be changed or is it hard coded and just the way it is?
I will more than likely not use Wah on every patch, but will probably have a volume pedal pre-amp to adjust input gain on the fly...I'd prefer to using the onboard for the volume and external for wah, but can't remember how it defaults per the manual.
For auto engage:
Menu
Bypass assign
Then change switch, position, and wait to what you want
Don't recall what all the defaults are, but you can change them to whatever you want.
Wah, bypass assign change to whichever exp (I use exp 2), controller assign change to whatever exp (again exp 2 for me). Plug your external exp pedal into exp3 to avoid all the weirdness.
