jaybee77
Linking up RC-300 + Helix using 1/4" Outs - Use Instrument or Line Level?
Hello.
Im loving the Helix and wanting to link up my Boss RC-300 looper to the helix.
Im going from the Helix 1/4" outs - into the L/R inputs on the RC300 - and then out to the stereo return on my Yamaha THR100HD
What should i set the Helix 1/4" outputs to - Instrument or Line ?
Info in the RC-300 manual is as follows....
INPUT
Nominal Input Level
INPUT INST: -10 dBu (variable)
Input Impedance
INPUT INST: 1 M ohm
OUTPUT
Nominal Output Level
MAIN OUTPUT: -10 dBu
Output Impedance 2 k ohms
Recommended Load Impedance 10 k ohms or greater....
I could also use a Helix F/X loop to connect to the RC300...
thanks for your help
With the 10m input impedance, any either one should work. You said variable, so I believe you can set unity gain that way.
If it can handle it, line would provide better signal to noise ratio.
I would contend that getting to line level sooner in a signal chain will have less noise issues if any
Thanks.
I have just got home and set it all up.
With the 10m input impedance, any either one should work...
- Did you mean 1 M ohm?
It is a  1 M ohm input impedance !
Tried both Instrument and Line. Line seems to have more noise/hiss than instrument - But im guessing that's due to instrument signal being lower in level so the Line seems to amplify more noise?
Yes i can set unity gain via the input 'Variable' level knob...
Will try the send return method... but then have to add an F/X block to every patch that i have made and the factory presets where as using the main 1/4" outs is straight forward - no editing of patches required...
