glassjaw81 Posted July 19, 2017 Share Posted July 19, 2017 Hi, more than likely a daft question! Got a Flextone 3 combo and bought a Laney 2x12 cab as my Flextone not a xl...I can't get the amp AND cab to work at the same time, it's either one or the other!! Any tips or am I being a retard! Quote Link to comment Share on other sites More sharing options...
BillBee Posted July 19, 2017 Share Posted July 19, 2017 Look on page 2-9 of the manual. For the Plus Model connect the external cab to the jack marked external. The internal one will disconnect the internal speaker. If you just have a Flextone 3 (not the XL or Plus) then you are pretty much SOL - if you do run the ext cab make sure it matches the correct impedance of 8 ohms (IIRC). Quote Link to comment Share on other sites More sharing options...
glassjaw81 Posted July 19, 2017 Author Share Posted July 19, 2017 So as Iv not got the xl or plus I'm screwed is what your saying? If I buy the XL it would work? Quote Link to comment Share on other sites More sharing options...
BillBee Posted July 20, 2017 Share Posted July 20, 2017 http://line6.com/data/6/0a060b316ac34f0593541385a/application/pdf/Flextone%20III%20User%20Manual%20-%20English%20.pdf An extension cab with the XL (heavy beast btw) disables the internal speaker (L or R) while the Plus lets you add a cab. I don't have a Flex III XL or Plus just the reg 1x12 which uses only the internal speaker. Quote Link to comment Share on other sites More sharing options...
glassjaw81 Posted July 20, 2017 Author Share Posted July 20, 2017 Well that answers that lol, mines the standard , not the XL or Plus, so only the plus will allow you to add a cab and run the 2 together, that sucks! Used to have the XL, your right it's heavy as you like ha ha! Am I right in thinking I can plus the pedal board I have into any line 6 and run it three with the saved patches! May as well buy a larger line 6! Iv only ever had a Flextone III And swear buy it, just looks tiny on stage hence wanting the extra cab! Quote Link to comment Share on other sites More sharing options...
