Open E String “Warble� On Bass
jackwagner
I am a Helix newbie. I have noticed that when I play an open E string on my bass and let it sustain, that it doesn’t hold a consistent pitch. It starts to “warble†a bit as if there were some slight modulation or tremolo effect. As if it were slightly out of tune (out of tune with what? I don’t know). This happens on all of the bass presets that I have tried. It doesn’t seem to happen on any other open strings.
I use this configuration in my practice room:
Bass->Helix Rack->Practice Amp (Aux In)
The bass is a Fender Precision. The Practice amp is an Ampeg BA-112v2 (a bass combo amp). I use the Aux In input to avoid the preamp section.
As a test, I connected my bass directly into the instrument input on the amp. It works fine – no warble.
Any ideas what may be happening?
Thanks,
--jack
Could be the noise gate on the input block. Have you tired turning it off... assuming you have it on?
Good idea. It is indeed ON. I will try turning it off to see if anything changes.
Thanks for the suggestion.
--jack
