POD HD Pro Patches/Setlists over to POD HD Pro X and Helix
aholland
I am looking for some guidance here -
Will my POD HD Pro Patches and Setlists transfer over onto a POD HD Pro X?
What about the same question relating to Helix?
Will my POD HD Pro Patches and Setlists transfer over onto a Heilx? Or will I need to start again from scratch?
Thanks for any assistance
Adam
the 500, 500x, pro, and pro x
are all the same unit.
There are some minor DSP differences between the x and non-x units, and there are some jack/pedal differences between rack and floor units.
But they are the same in terms of coding.
The only issue with a transfer of files is the extension they each use.
If you drag-n-drop, it isn't a problem. But if you try to use the drop-down box, the computer won't see the files because it looks for a different extension based on which EDIT you are running.
