fotogestaltung 0 Posted August 13, 2017 I have a Marshall 9100 poweramp, a JMP-1 and the Helix LT. Right now it´s set up like this: 1. Guitar>Helix guitar input 2. Helix Send>JMP-1 guitar in 3. JMP-1 Send>Helix Return 4. Helix 1/4 out>Marshall 9100 poweramp input Can I use the JMP-1 Output instead of the JMP-1 Send (in step 3)? If yes, what´s better and why? Quote Share this post Link to post Share on other sites
spikey 699 Posted August 13, 2017 You do want to run post effects "after" the JMP-1 preamp, right? To do this, the signal needs to go back into Helix so that you can add those effects (mod, delay, reverb) via the editor/ or front controls. Also, in using Helix before the send to the JMP-1, you can add a wah, eq, and other stomps. If both the send and the output of the JMP-1 are line lvl Im not sure why it would make a difference (other than for normality) to use either one. Make sure that the output is the same level as the send, so that no damage will occur to the Helix return in port. Hope this helped. Quote Share this post Link to post Share on other sites
coachz 5 Posted August 13, 2017 Doesn't helix have all those Marshall sounds? Quote Share this post Link to post Share on other sites
spikey 699 Posted August 13, 2017 Yes, Helix also has some nice drive pedals but I prefer to also use my "La-Grange and Riverside" pedals too. Quote Share this post Link to post Share on other sites
fotogestaltung 0 Posted August 13, 2017 You do want to run post effects "after" the JMP-1 preamp, right? To do this, the signal needs to go back into Helix so that you can add those effects (mod, delay, reverb) via the editor/ or front controls. Also, in using Helix before the send to the JMP-1, you can add a wah, eq, and other stomps. If both the send and the output of the JMP-1 are line lvl Im not sure why it would make a difference (other than for normality) to use either one. Make sure that the output is the same level as the send, so that no damage will occur to the Helix return in port. Hope this helped. Yes, I want to run some effects in front and some after the JMP-1. This works perfectly right now. I was just wondering, wether using the "Output" instead of the "Send" would make any difference. Quote Share this post Link to post Share on other sites
spikey 699 Posted August 13, 2017 Depends on whats between the send, and the output. Is there an EQ, or scooping control or something of that nature after the send? Quote Share this post Link to post Share on other sites
TheDaveDaveDave 42 Posted August 13, 2017 I have a Marshall 9100 poweramp, a JMP-1 and the Helix LT. Right now it´s set up like this: 1. Guitar>Helix guitar input 2. Helix Send>JMP-1 guitar in 3. JMP-1 Send>Helix Return 4. Helix 1/4 out>Marshall 9100 poweramp input Can I use the JMP-1 Output instead of the JMP-1 Send (in step 3)? If yes, what´s better and why? You could, but I recommend keeping the setup the way that you have it now. I run my Mesa Triaxis with the same wiring scheme as you. I prefer it because: Fewer volume pots and buffers - less circuitry in the path makes for a lower noise floor Not worrying about yet another volume knob - in your case two with the JMP1. Fiddling with the preamp's output level will change the gain structure of effects/amps in the Helix. When things go wrong (because they inevitably do) you'll scratch your head one fewer scratch before you solve the problem. I.e., you'll look cooler on stage. There is ONE change I'd recommend if you haven't done it yet - YMMV, but it could really improve your tone: Use Helix Send 1 to the JMP input, and set it to "instrument" in global settings; then connect the JMP1 1 send to Return 2 on the Helix, and set it to "line". Hope this helps! 1 Quote Share this post Link to post Share on other sites
fotogestaltung 0 Posted August 14, 2017 Dave, thanks for your help! That makes sense. But one more question: You said: "........then connect the JMP1 1 send to Return 2 on the Helix, and set it to "line"." Why "Return 2" and not "Return 1"? What´s the difference between Return 1 and 2 on the Helix LT? Quote Share this post Link to post Share on other sites
CraigGT 73 Posted August 14, 2017 There's no difference but you can only set line/instrument level per pair of send returns. You need your send to be instrument level and your return needs to be line so that's why TheDaveDaveDave recommended to do it that way. Your main 1/4" out needs to be set to line level too. Craig 2 Quote Share this post Link to post Share on other sites
PeterHamm 653 Posted August 14, 2017 If I were you, I'd put the JMP-1 aside, try the amp preamps that are in Helix, and then when you find out they work better you can sell the JMP or put it in storage. Quote Share this post Link to post Share on other sites
coachz 5 Posted August 14, 2017 If I were you, I'd put the JMP-1 aside, try the amp preamps that are in Helix, and then when you find out they work better you can sell the JMP or put it in storage. That is the point of having a helix imo. Quote Share this post Link to post Share on other sites
PeterHamm 653 Posted August 14, 2017 That is the point of having a helix imo. yeah, and Helix's relatively brand new modeling technology will almost certainly destroy JMP1's 25-year-old tech. Quote Share this post Link to post Share on other sites
TheDaveDaveDave 42 Posted August 15, 2017 There's no difference but you can only set line/instrument level per pair of send returns. You need your send to be instrument level and your return needs to be line so that's why TheDaveDaveDave recommended to do it that way. Your main 1/4" out needs to be set to line level too. Craig Yup - this! Quote Share this post Link to post Share on other sites
TheDaveDaveDave 42 Posted August 15, 2017 yeah, and Helix's relatively brand new modeling technology will almost certainly destroy JMP1's 25-year-old tech. Well, there's no harm in checking it out and really A/B'ing them. FWIW, I've got a small stash of 60 year old Telefunken preamp tubes, only one of which I've been using in different preamps. Sure, the Helix does a lot of tones, but until they model my Mark V with a Telefunken.... or the Tri.... Only truth is what you hear :) Quote Share this post Link to post Share on other sites
fotogestaltung 0 Posted August 15, 2017 I just love the JMP-1 and will continue to use it. Maybe until I find a lead sound in the Helix that is better. But there are so many possibilities that that could take a while. Especially the mids in the JMP-1 are very flexible and I set them to a higher value than probably most other people. And that special sound is not easy to achieve, because the mid controls of most other amps (and also the Helix) react different IMO. Of course I could also use an EQ in addition. So time will tell..... I also know now, why I was told to use Return 2 instead of Return 1. If you set the level to instrument or line, it´s always for send and return in the LT. So, if you want instrument for send and line for return, you have to use different send and return loops. Quote Share this post Link to post Share on other sites
TheDaveDaveDave 42 Posted August 16, 2017 --- edit --- oops, wrong thread! --- Quote Share this post Link to post Share on other sites
fotogestaltung 0 Posted October 2, 2017 Here´s another question: As already said that´s the Setup: 1. Guitar>Helix guitar input 2. Helix Send>JMP-1 guitar in 3. JMP-1 Send>Helix Return 4. Helix 1/4 out>Marshall 9100 poweramp Input As soon as I activate the send and return loops of the Helix, I get a terrible hum. It´s rather low with the JMP-1´s clean sound and terrible with it´s distored sounds. Even if I set my guitar´s volume to 0, I get that hum. I´ve tried the JMP-1 and the 9100 alone and there´s very little noise, just normal for tube amps. So they are okay. I´ve already seen, where the noise comes from: It´s the cable that goes from the Helix send to the JMP-1 guitar input. I´ve tried different cables, but no change. If I move the cable around the hum changes very much, just like it´s an antenna. I´ve already disabled WLAN in the room, just to make sure, it doesn´t influence anything. I´ve set the send output Level to lower settings, but the signal/noise ratio stays the same. Hum is lower, but my guitar sound also. I´ve tried different wall sockets, but no change. Any ideas, what I could do? Quote Share this post Link to post Share on other sites
nib2000 0 Posted October 9, 2017 That sounds like a grounding issue somewhere honestly. What is you go Helix>Power Amp? Next step is to plugin JMP in 4cm like you would normally do, but disable Loop in a patch. If the setup is still quiet, enable loop. If its noisy at this point, it's gotta be one of the loop cables Quote Share this post Link to post Share on other sites
CraigGT 73 Posted October 11, 2017 Have you made the changes that myself and theDaveDaveDave said earlier about using two seperate send/returns to get the levels right? Quote Share this post Link to post Share on other sites
