Controlling and Using a tube amp
Tehzim
Yeah it is just standard 4CM. If you just want the preamp sounds into a power amp with out using the physical amps preamp you don't need to do 4CM, you could just go guitar to helix to power amp (effect loop return). Helix can act as the foot switch for amp channel changing if the amp uses 1/4 jacks for controlling it.
  • 1 year later...
How exactly does the Helix switch channels on amps via a 1/4 jack?
