Popping/Crackling in DT25 even after tube replacement and biasing
the29band
I got my DT25 tubes replaced (both preamp and power) with the following tubes below, earlier this week. I confirmed that Line 6 recommends these tubes. The tech had also biased the amp post replacement.
http://www.musiciansfriend.com/accessories/electro-harmonix-el84-matched-power-tubes/210092000118185?source=3TEM5KTBK
http://www.musiciansfriend.com/accessories/electro-harmonix-12ax7eh-preamp-tube?source=3TEM5KTBK
However, the amp is making crackling noises in Class A/B mode but NOT in Class A.
Thoughts?
Wondered that myself, but it only occurs with hummers.
If it was the cable I would expect it pop and crackle on both hummer and single coil.
Unless there's something odd with the cable ground, that it would only occur with the humbuckers.
