3leggedbrain
Will IR's work via Effects Send/Return
When playing my acoustic guitar, I plug directly into my fishman amp and connect to my Helix via the effects return/send channels, basically using the Helix as a pedal board.
In this way, will an IR have any effect on my sound? Or does it function in a different way than say reverb or delay or whatever?
Thanks!
Brian
If you get the routing setup correct (send/return), you can use an IR block in Helix to process your acoustic/Fishman rig.
Thanks, Jim.
Not sure if you are saying that I can only use an IR block if I plug the guitar into the helix first? I know that the effects blocks like reverb, delay and distortion work fine when I plug into the fishman and then use the fishman send/return to access the helix....
