Bluesman27
V120 - XLR Outs Silence the Amp?
I tried to connect a PA using a cable from the XLR out, but the amp speakers are then silenced.   I would like to use the amp as a monitor while sending the signal to a PA.   Is there a way to have the amp on with an XLR cable connected?   Or can this be done using a cable in the headphone out connection?
Plugging into the XLR outputs doesn't mute the speakers, so there has to be another problem.
Oops....I stand corrected.   Thanks GTRMAN100!   I had tried to use the XLR outs on a gig the other day and it seemed to cut out the amp speakers.    Not sure what I was doing wrong, but I tried this again at home after hearing from GTRMAN and he is right....the speakers were not muted when using the XLR connection.   SO....all is well again in Line 6 Land.
