indianrock Posted September 2, 2017 Share Posted September 2, 2017 I think the Global EQ default low-pass frequency is 8 Khz ( attenuation on frequencies above that. ) Now that I'm using new in-ear monitors with 4 drivers per ear, I"m hearing more finger slide noise on my strat. I suspect this isn't an issue in the PA mains and only in my ears so maybe it wouldn't be a good idea to adjust the low-pass lower. ?? Fret/string lube already sprayed on. KZ ZS5 in ears Quote Link to comment Share on other sites More sharing options...
indianrock Posted September 2, 2017 Author Share Posted September 2, 2017 Thanks. By parametric, you're referring to a standard parametric EQ effect that can be inserted into a patch, correct? Quote Link to comment Share on other sites More sharing options...
