Sign in to follow this
WilliamRRossII
Delay L/R with Pitch Transposer and wet/dry signals
Hi there!
Here's what I'm trying to do:
1) Create a clean signal that will play straight through, center pan. Easy.
2) Take the same signal and run it panned hard left through a delay and pitch transposer where the wet only signal plays 260ms AFTER the original signal, dropped -7th via pitch but no original note, only the -7th, panned hard left.
3) Using the same original signal, run it panned hard right through a delay and pitch transposer where the wet only signal plays 520ms AFTER the original signal, raised +5th via pitch but neither the original signal nor the left dropped 7th coming through.
Center, then hard left dropped a 7th, then hard right raised a 5th. Three notes, not overlapped. Center, left, right.
This is day one with my new POD HD PRO X.
Thank you!
