Thurston9 33 Posted September 14, 2017 Does anyone run both through Helix together? What input do you use for bass? Quote Share this post Link to post Share on other sites
FarleyUK 13 Posted September 14, 2017 I don't normally, but I have done at a couple of gigs. Use the AUX IN for the bass. Quote Share this post Link to post Share on other sites
Joepeggio 76 Posted September 15, 2017 At the same time or switch between? I use wireless. So all through guitar in. Quote Share this post Link to post Share on other sites
plumber 4 Posted September 15, 2017 we use 2 guitars and 1 bass through 1 helix with separate effects chains works perfectly guitar in main input and fx in 1 bass in aux Quote Share this post Link to post Share on other sites
TLF2007 30 Posted September 15, 2017 I set up guitar and bass through my Helix for gigs. When I switch to guitar, our harmonica/key player takes over bass. I never use a guitar amp just the wedges for stage monitoring. I sometimes use a Fender Bassman amp just for bass over my Alto 210's if i'm in the mood but my bass signal going to FOH is pretty much direct with no amp emulation, that is just for the stage. ( I use amp emulation for guitar for both stage and FOH) All goes to FOH for the sound support to do what they need I use the standard guitar in for guitar and the Aux for the bass with a 15 dB bump via a gain block in the front end because my bass has an EQ preamp but is not technically "active". I've gotten around the low dB on the Aux input by using a Return as a bass or guitar input as well but in the end I settled on the way I have it now. No real reason other than it was there and easier to navigate input for setup so I can get onto the next thing. ( I'd constantly plug into the wrong 1/4"). Quote Share this post Link to post Share on other sites
hal3001 4 Posted September 15, 2017 We actually used it with 3x Line6 G90s for two guitars and a bass for a little while. I just ran them all to effects returns set to instrument level and it worked perfectly. You definitely can't get too creative with the effects because of DSP limitations (not really a problem as I'm pretty sure they've never marketed it as "run your whole band through a single device with unlimited effects") but it was definitely do-able. We did eventually split everyone up to their own gear (Firehawk FX for the second guitar and an SVT 7 Pro for bass) so they could have control of their own gear but I imagine if the guitars and bass had a few of their own pedals (assuming you were they were wired) you could definitely make it work. Quote Share this post Link to post Share on other sites
Optimist 4 Posted September 15, 2017 I experienced that Return is better than Aux for two instruments with the same outputs (e.g. passive single coils). I use Guitar In with my strat and my teacher uses Return 1 with my tele – each on its own signal path (with the same blocks/settings). Both guitars sound equally (aside from their native characteristics). Using Aux for my teacher resulted in a much quieter tone from him, so we switched to Ret 1. Might be as well practicable for bass. Quote Share this post Link to post Share on other sites
Thurston9 33 Posted September 16, 2017 Great responses, thanks all appreciate hearing about your experiences. Quote Share this post Link to post Share on other sites
