HD500X midi control of Lehle 1@3
jclose
My goal is to have the HD500X send midi to turn on/off channel A on the Lehle 1@3.
Practical application is to turn off the virtual HD amp in an HD500X patch. This will mute the DT25 and allow the signal to pass with effects to the Lehle switch connected to an Avatar 45 Watt. Turning on the virtual HD amp will switch off Lehel channel A, muting the Avatar and allowing signal to pass to the DT25.
The Lehle can receive (and send) midi on any channel and can be programmed to respond (channel on/off) to incoming midi.
http://lehle.com/EN/Lehle-1at3-SGoS
Need some help with the HD500X midi side...
