SciFi Posted October 6, 2017 Share Posted October 6, 2017 Hey I'm wondering if I could connect my Firehawk1500 with a classic tube amp to use tube amp preamp channel/distortion, then Firehawk1500 effects, then again signal back to tube amp and his speaker cabinet. I could imagine a signal chain like this: Guitar into Tubeamp Guitar in -> tubeamp effect send into firehawk guitar in ( no amp selection in firehawk ) -> mod/dly/rvb/others active in firehawk -> fx loop on -> fx send -> tubeamp effects return -> tube amp amplification and finally tube amp speakers. Would that be possible? Or is it just theoretical and in the end it would sound horrible? What about the signal level from tube amp fx send into firehawk guitar in plug? Is that a NO GO or are there other problems I don't know of? Second thought was, using the signal chain from above and additionally using the firehawk as a monitor from the PA. What are your thoughts? THX Simon Quote Link to comment Share on other sites More sharing options...
talwilkins Posted October 7, 2017 Share Posted October 7, 2017 I think it would be a very heavy (35 Kg) effects modeler. You might like to try the Firehawk FX or even better a Helix (LT). Then you can also control the effects Quote Link to comment Share on other sites More sharing options...
zivdud Posted October 27, 2017 Share Posted October 27, 2017 I got my helix running into my Firehawk 1500 and than another line into the poweramp of my Dt50 and a wireless split before the helix that goes into it and into the front of the dt50. It is overkill but so sweet. Quote Link to comment Share on other sites More sharing options...
talwilkins Posted October 29, 2017 Share Posted October 29, 2017 I got my helix running into my Firehawk 1500 and than another line into the poweramp of my Dt50 and a wireless split before the helix that goes into it and into the front of the dt50. It is overkill but so sweet. Wow, I could try that with my FH1500 and DT25 Quote Link to comment Share on other sites More sharing options...
zivdud Posted November 5, 2017 Share Posted November 5, 2017 It is a blast and for some of my presets that are so effects heavy I was loosing my clean guitar signal that I wanted to cut through the mix with so I use the dt50 for that. Quote Link to comment Share on other sites More sharing options...
