Can the looper feed the input path?
d-flat
New Helix LT owner, had it for only about a week now. Wondering, can the looper be used to record a dry signal, then feed it back as input to path A or B? I'd like to record a riff, loop it, then play with dialing the knobs on an amp, try out different amps on the riff, etc. I have a feeling I could do this by recording a dry track on a DAW, then outputting it into the Helix, but hoping these is a way to accomplish this on a helix without the need for a daw.
Thank you both. That was my first post and I forgot I did it because I didn't set it up to auto notify me of replies. Right after I had the idea, hey, maybe I should put the looper first in the path. And it worked. Duh. Feel dumb for asking now. Thanks again.
