Ada mp1
shredzilla1964
MP-2 had expanded features from the MP-1 unit.  Did it sound better?
Not necessarily, but it had more gain control, better loops, great chorus and wah built in.
Really cutting edge for the time.
MP-2 Features
Complete digital control of an all-analog signal path.
128 User programs plus 39 factory Preset programs.
Two low-noise 12AX7A tubes with 10 tube voicing settings and overdrive.
Onboard compressor for maximum sustain and funk squeeze.
Four-band tone controls for basic tone shaping.
Nine-band graphic equalizer for detailed tone adjustments.
Powerful effects, including wah-wah, tremolo, and stereo chorus.
Noise reduction circuitry to reduce unwanted hum and noise at high gain settings.
Stereo effects loop with programmable mix control. Side-chain design keeps dry signal within MP-2, preserving dynamics and signal-to-noise ratio.
Speaker emulation circuit and room compensation equalization.
Cabinet-emulated, balanced XLR outputs with ground lift, as well as unbalanced 1/4" phone outputs for recording.
Independent unbalanced 1/4" phone outputs for stage use.
Front and rear panel 1/4" phone inputs for easy access.
Complete MIDI implementation, including Real-Time MIDI for changing parameters "on the fly."
Optional MIDI Controller Pedal Pack provides instant access to any program for fast on-stage control, plus real-time MIDI continuous control.
