Sign in to follow this
isaiahb93
What do I set my Helix LT output to?
I am about to buy a Helix LT and I am going to run it through my 4 channel PA mixer and speakers. I am unsure of what to set the output on the Helix to. On the POD HD500x I set it to Studio Direct mode but I don't see that option on the Helix. How exactly should I run it? Should I use XLR or 3/4 inch cable?
Also, I don't understand why there are 2 Parallel lines on the patch setup screen. What would that be used for?
1. You can use XLR or 1/4", however you want to do it. You can set outputs to mic or line level, I believe they are set to line by default.
2. You may want to hit the Youtubes and watch some videos on building presets in Helix.
