Helix and Workbench HD not working, Help Help
Hi All
Ok So i am losing my mind trying to get Helix and Variax JTV 69 working. I installed a brand new Windows 10 install
and no matter what always get 'The connected Variax is not compatible with Workbench HD.
You must use a James Tylers Variax version 2.0 or higher' so I go and disconnect the Variax completely and get the exact same error so it appears that really the message is bogus. I have the supplied VDI cable and have tried several CAT 5 and Cat 5 E cables still always get the same error.
Does any know exactly why this doesnt work? Does having Line 6 POD HD 500 installed as well as helix cause this? I did not try uninstalling Line 6 monkey
but did disconnect the line 6 POD 500.
I just cant figure out how this doesnt work and why my system only
FYI Line 6 Support says they have no idea and it 'should work;!
Here is my Black Friday recording with 2.30 firmware
help help
Connect the way you normally would for Monkey update or Workbench HD
with the the interface device and cables that came with the JTV.
Unplug any USB hubs that may be connected.
Insert a fully charged JTV battery into the compartment, then plug a stereo headphone adapter
into the 1/4" jack. Listen for the click of the relay engaging. There should be two green LED's on
the interface device.
Check Line 6 Monkey for the Firmware version on the JTV guitar. If it is not v2.00 or higher, Workbench HD
will not recognize the guitar.
Once all this is completed, you should be able to open Workbench HD.
Check the online Pilot's Handbook and the Knowledge Base on this subject for further details if needed.
Hi.. fwiw, I have a an iMAC and Workbench HD along with HX Edit, JTV and Helix LT
Workbench HD is very very intermittent connecting to my JTV, and I get the same message you see.. the one about the software version on the JTV.
I've tested various connectivity scenarios and the Workbench HD sometimes connects, sometimes doesn't and sometimes connects then fails to communicate with the JTV when settings are changed..
Currently my chain looks like this..
MAC USB --> Helix LT --> JTV (via the cat 5 cable).
This is the most stable connectivity sequence I can get.... dropping out the Helix makes connectivity to workbench worse..
Basically, workbench is useless to me, so the value of it is wasted.
I'd like a solution, but it looks like this issue isn't restricted to Windows... it's MAC too..
Help anyone?
PS, everything (including the iMAC) is running latest available firmware..
Thanks
