pepitovadecurt
Helix and classical guitar
Hi I'm using Helix for live (directo to PA from XLR stereo) in electric guitars.
Now need to incorporate a classical guitar with piezo and onboard preamp Shadow. After few tests uses the loop input (in my guitar sounds better than AUX in). Sometimes the guitar sounds with a lot of bass, sometimes sounds thin, sometimes produces a lot of feedback...
Any recommendation to sound good for both guitars with the same outputs? And to get better tone with the classical guitar? I play rumba.
Thanks.
umm.... what's causing all the sometimes this and that stuff?
Are you adding effects?
Do you have an amp sim on?
Do you have a bad cable?
For me, when I plug an acoustic in, I tend to use no amp and just add a touch of reverb and/or delay.  Too much reverb and you'll get feedback.  If feedback is a problem, you could try adding an eq and sweep a high q cut through till you find the offending frequency range.
Using a compressor or adding gain from an amp will increase the likelihood of feedback.
Yah - my acoustic patches are comp>eq>delay/verb and that's about it.  Nylon or steel string, I get good results.  Start simple and consistent, go from there.
Always add a Studio Tube Pre and some reverb.
FlyingsCool, where is the Amp Sim?
Any general guide to eq a nylon guitar? Usually cut the low freq to 80Hz and the high to 10KHz.
Create an account
Register a new account
Sign in
Sign In Now
