redarmy82 Posted December 2, 2017 Share Posted December 2, 2017 Can anyone explain to me how in the hell to calibrate the tuner on this thing? I'm trying to play along to solo over backing tracks and the amp says I'm in tune, but I sound out of tune to everything. Quote Link to comment Share on other sites More sharing options...
thorneven Posted December 2, 2017 Share Posted December 2, 2017 I don't believe you can calibrate the tuner. If you need the tuner to tune and it allegedly doesn't work, how do you know you're out? =:-) (Sorry, I couldn't resist) I sometimes tune using harmonics. For example, on the low E play the harmonic at the 5th fret and then on the A, the harmonic at the 7th fret. Listen for vibrations. When the 2 notes stop vibrating, they're in tune. Quote Link to comment Share on other sites More sharing options...
Raykpt Posted January 30, 2018 Share Posted January 30, 2018 My tuner needs recalibration as well. It is a half step lower than my other tuners. If the tuner cannot be recalibrated can someone point me toward the instructions for a factory reset? Thanks Quote Link to comment Share on other sites More sharing options...
thorneven Posted January 30, 2018 Share Posted January 30, 2018 From a Google search: Q: How do I perform a factory reset on the Spider V series? A: Hold down the Home button to access the settings menu. Scroll down with the encoder to where it says Factory Reset. Scroll to the right and press the encoder knob to hit Yes. 1 Quote Link to comment Share on other sites More sharing options...
Raykpt Posted January 30, 2018 Share Posted January 30, 2018 From a Google search: Q: How do I perform a factory reset on the Spider V series? A: Hold down the Home button to access the settings menu. Scroll down with the encoder to where it says Factory Reset. Scroll to the right and press the encoder knob to hit Yes. Thank you! Quote Link to comment Share on other sites More sharing options...
