Hangman85 Posted October 6, 2013 Share Posted October 6, 2013 When I power up my laptop my Kb37 does not work as it should, first of all the "octave select" light never lights up and then when I try to use it with Cubase it tends not to work correctly in these circumstances. However, if I simply unplug the USB from the KB37 and plug it in again everything works as it should. Interestingly, if I restart the computer rather than shut down and power up again, the problem does not occur - it only happens when powered up from being shut down and completely off. I have tried uninstalling and reinstalling - no change. All software and drivers are up to date. I am using my KB37 in conjunction with a new Lenovo laptop running windows 8 64-bit. Any ideas what I should do to stop this from happening? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted October 6, 2013 Share Posted October 6, 2013 I would guess that perhaps your computer is not sending enough power over USB on startup... other than driver updates i can't think of anything that would help... google and use slimdrivers... it will find some behind the scenes driver upgrades that may help. Quote Link to comment Share on other sites More sharing options...
FrankLo Posted October 6, 2014 Share Posted October 6, 2014 Did you found a solution? I've the same problem with my new KB32 an an ASUS Transformerbook. Quote Link to comment Share on other sites More sharing options...
FrankLo Posted October 7, 2014 Share Posted October 7, 2014 Okay, I tried what TheRealZap said. SlimDrivers has updated some Intel drivers. After starting the computer it worked once but after this it is the same problem again. I hope my English is understandable. Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 7, 2014 Share Posted October 7, 2014 It may also be a BIOS setting looking for a bootable USB OS. But I guess a simple solution would be not to plug it in until after booting up. 1 Quote Link to comment Share on other sites More sharing options...
FrankLo Posted October 9, 2014 Share Posted October 9, 2014 Hi Triyche, iI tried all USB settings in the BIOS but with no effect. The simple solution you have proposed I have been practicing since I have the KB37 ;-) But I thought that there is maybe a solution for the normal way. Now it is how it is. Thank you. Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 9, 2014 Share Posted October 9, 2014 Yeah, my hunch is what Zap figures, not enough power at start up. Have you tried with the laptop plugged in? If it works that way then for sure it's a power issue. Quote Link to comment Share on other sites More sharing options...
BillBee Posted October 9, 2014 Share Posted October 9, 2014 I am not sure how much of this would apply to Win8 (don't have it) but in the older Windows versions you could go into the power management settings via Device Manager - Hardware to the USB Root Hub. It might be worth a trip through the search engine to see if there is a setting which is causing this. -B Quote Link to comment Share on other sites More sharing options...
FrankLo Posted October 14, 2014 Share Posted October 14, 2014 Okay, I have solved the problem. I have disabled the fast startup in the power options. Now it works correct. Thank you all for your help. 1 Quote Link to comment Share on other sites More sharing options...
the_clause Posted December 28, 2015 Share Posted December 28, 2015 Hi, I'm having this EXACT same problem (I have done the past year, I'm close to throwing the KB37 out, but thought I'd check if someone is encountering similar issues here first!)...... I'm running on Windows 10 small form factor desktop.....MIDI does not work when booting PC from cold, the octave select lights are out, though audio works fine. A restart or pulling the cable out/in solves it.......sometimes for not very long.....if I start using Reaper the MIDI might freeze up halfway through a session causing everything to go haywire, requiring a PC reboot to resolve.... From FrankLo's text I have disabled quick boot in my BIOS, but I still have the problem......does anybody have any suggestions? Quote Link to comment Share on other sites More sharing options...
Brazzy Posted December 28, 2015 Share Posted December 28, 2015 It may also be a BIOS setting looking for a bootable USB OS. But I guess a simple solution would be not to plug it in until after booting up. This is what I've been doing. I just unplug it before I shutdown or hibernate and after the 'puter is finished starting I plug it back in. Quote Link to comment Share on other sites More sharing options...
the_clause Posted December 28, 2015 Share Posted December 28, 2015 I misunderstood FrankLo..........Fast Startup is the hybrid shutdown/hibernate stuff built into Windows 10. As soon as I disabled it all started to work again from cold starts......awesome http://www.windows10update.com/2015/05/windows-10-tutorials-66-how-to-enable-or-disable-fast-startup/ Quote Link to comment Share on other sites More sharing options...
