mikisb 29 Posted December 6, 2017 Hi, love to have a looper onboard, but probably i'm doing something wrong with it. I record a sequence - everything's fine. I play the sequence back - everything's good. But when i play along with the loop (no overdup, just playing without additional record), it sounds like dropouts in the live signal while the loop seems to playback fine. Happens with different amp models, doe'snt matter if there are plenty of effects or just a simple setup. I have the looper on the first place after the input to make it easier to tweak. What i'm doing wrong? Quote Share this post Link to post Share on other sites
shanecgriffo 75 Posted December 6, 2017 what do you mean dropouts.? the volume randomly drops on your live guitar? drops just a little or drops right out? do you have a compressor after the looper? it may be messing with the signal if 2 guitars are going into it.. Quote Share this post Link to post Share on other sites
mikisb 29 Posted December 8, 2017 well - difficult to explain cause it seems to bea bit different sometimes <_< Just tried it again with the looper in front of a simple setup. So i recorded a loop with the volume on the guitar pretty down for a crunchy rythm. (wich works great with the Derailes Ingrid) Then i play this record (ni oberdubs), turn the guitars volume up. When i ply now with the loop, the looped rythm-guitar dissapears completly and comes back immediately when i stop playing. Strange - is'nt it? Quote Share this post Link to post Share on other sites
