EVERYTHING COMES ON, I CAN SWITCH THROUGH ALL MY PRESETS....IT JUST HAS A CONSTANT OSCILLATING NOISE COMING THROUGH IT.  NOT SURE WHY.  ANYBODY HAVE ANY THOUGHT OTHER THAN MAYBE A BAD POWER SUPPLY?
Its a toughie, could be an internal component which would be a trip to the service center. But you should run through the usual procedures. Back up the patches, check all cables and connections, batteries - if using active pickups. The first thing in the signal chain is the tuner so check that the tuner is seeing a signal. But yes the PS can cause some odd behavior. Last but not least its time to reflash the unit.
If no else can give you a specific fix it is Support Ticket time.
Sign in to follow this
