Helix as Interface on Linux
jonandtice
Has anyone successfully been using the Helix as an audio interface on Linux?  I'm running Ubuntu 17.10 and the Helix does not show up as a device in the sound settings.  It is also not listed as a device if I run
aplay -l
When I start jack (using Cadence from KXStudio) it is not listed in the configuration section.
If I run
alsamixer
it is listed as a soundcard (Helix).
lsusb
also lists the device.
I'm not expecting to be able to use HX Edit, just use the Helix as an audio interface.
  • 1 month later...
  • 2 years later...
Wanted to share small update on current state of Linux support.
I am using Fedora 31 kernel 5.5.11-200.fc31.x86_64 that has out-of-the-box support for Helix product line.
I am able to use Ardour to record and playback on multiple channels.
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
On 4/26/2020 at 5:39 AM, mac2222 said:
I've just tried Kubuntu 20.04 and helix is working out of the box with no additional configuration.
I'm also running Kubuntu 20.04.
I have yet to try and use my Helix with it though.
How consistently are you getting it to work and does it stay connected?
Thanx!
Juan
  • 3 months later...
I can confirm this is working in ubuntu 20.10, kernel 5.8.0-29 without any patching of the kernel.
I have a question though, was anyone able to change the sample rate to 96Khz? HX Stomp is capable of this and is Class 1 compliant so the drivers should be fine. But changing the sample rate in Jack Audio Connection Kit produces no change (the gui still shows 48KHz even after restarting the client).
