Sign in to follow this
efrati
How to set a minimum volume with the expression pedal?
I suppose it is very simple, but I can't find out how to do it.
If I use a volume pedal block: how can I adjust the minimum volume? I mean I don't want to start from zero, but I'd like to go for example from 50 to 100%.
Is it possible?
Or do I have to link the amp channel volume (for example) to the expression pedal to get this effect?
Thanks for any tip!
Select/highlight the volume pedal block in the preset. Press the button with the 3 lines (upper left by the save button). Press dial 2 under the screen (now labelled controller assign). There you will have options including max and min values.
May affect things?... in global settings/expression pedals I have all 3 set to per preset
Or select the volume/gain block and press down and hold on the knob that is the parameter you are changing that will open up the controller assignments too
This. Go to your volume block, hold down the knob that controls volume, the menu will come up where you can set min and max.
Thank you very much for your helpful information!
It was pretty simple, but - I don't know why - I didn't think about it, because I'm used to the "knob hold-down" only when I assign something to a switch or to a snapshot.
PS: ops, I see now that I have two different profiles here in this forum and I thanked from the other one. Well, it doesn't matter. Thank you anyway!
